Author Topic: Floor Tiles - aligned with floor curve  (Read 30986 times)
timjj
« on: November 11, 2019, 01:40:00 am »
Hi all,
I have the paid for Railclone pro version but its registered to the studio I work for, not my personal account on here so have had to post in the lite version - sorry.
Question I have is, I am trying to create large format tiles and the client wants them to be alingned with the wall rotation so it sweeps around as per my attached image. Is is possible to do this? I have a half tile to start the offsets and then the full tile to create the rest. Ill attach the style sheet anyhow.
Appreciate at help I can get. Thanks in advance.
Tim
Ideal Tile Alignment
https://ibb.co/mDTwsFh
Style Sheet
https://ibb.co/dDGm2cy
Re: Floor Tiles - aligned with floor curve
« Reply #1 on: November 11, 2019, 02:49:01 pm »
You should be able to associate this account of the forum with the "Pro" license account under User Panel - Forum - Forum Accounts.
That should be possible to be archived by using a "nested style" - in a very similar way like in this tightly related post. I hope you'll find it useful.
« Reply #2 on: November 11, 2019, 03:12:04 pm »
Hi, maybe this can help you but it is RC4.
Parameters:
Enter the Path Width.
If the pattern is wrong, just try to checkbox `Fix pattern`
Best Regards
« Last Edit: November 11, 2019, 03:24:35 pm by Dragan »
timjj
« Reply #3 on: November 11, 2019, 11:12:51 pm »
Thanks Dragan,
Opened it up but unfortunately we only have 3.2.0 here at work.
It loads all the parameters but the editor is broken and nothing generates. Ill try to get our RC updated and try it then. Thanks again, Appreciate the effort!
Tim
timjj
« Reply #4 on: November 11, 2019, 11:43:58 pm »
Just saw your reply Michal, cheers also for it.
Ill look into getting my account associated, had a quick look but didnt find what you spoke about getting my account on the pro side. But all good for now. Still quite new to RC.
That link you posted looks promising. Ill give it a go also. Cheers!
Appreciate the info.
« Reply #5 on: November 11, 2019, 11:48:10 pm »
Try it now. I nested two RC objects.
For RC1 you can import your Segment and for RC2 select path and clipping area if needed.
Set parameters for Path Width on  RC1 and Clipping mode and Alignment on RC1.
« Last Edit: November 12, 2019, 08:16:50 am by Dragan »
