Author Topic: Forest light with Max design 2010  (Read 21251 times)
phxdwl
« on: October 27, 2010, 11:28:54 pm »
i tried to intall forest lite with max design 2010, it did not intall correctly but it worked in regular max 2010. so i copied the ForestPackLite.dlo into the plugins dir under the 3ds Max Design 2010 dir. it appeared to work unitll i tired to render and i got a mental ray error.
'forestgeom' : shader declaration "fs_geom3" not found
is forest compatible with max design
yuv
  • iToo Software - CEO
    • Itoo Software
Re: Forest light with Max design 2010
« Reply #1 on: October 28, 2010, 12:10:42 am »
Yes, all our plugins are compatible with Max Design 2010.  This error is caused because the Mental Ray shaders are not found, there are some files apart from the .dlo that must be installed properly.
To solve this, please run the Forest Pack installer, select Max 2010 and the path for your 3DSMax Design installation.
Daniel Quintero
Itoo Software
www.itoosoft.com
daniel@itoosoft.com
