Author Topic: Forest Lite 6.1, Surface Rollout disabled?  (Read 89121 times)
Tommy_
« on: January 29, 2019, 12:54:27 pm »
I recently installed FP Lite 6.1.5 because I upgraded to V-Ray Next. I now use 3ds Max 2018, but tried on Max 2017 as well. It appears that the Surface parameters are disabled, and it wasn't like that in earlier FP Lite (5.4). I can't add, delete nor update my surface. I can only pick my surface when creating a new forest, then I'm stuck with it.
Should it be that way, or is something corrupt in my installation?
Re: Forest Lite 6.1, Surface Rollout disabled?
« Reply #1 on: January 29, 2019, 01:36:28 pm »
This is limitation of Lite version.
If You require unrestricted version please consider upgrading to PRO license.
If You have any questions about PRO license feel free to ask.
Tommy_
« Reply #2 on: January 30, 2019, 08:34:40 am »
Thanks for the answer! What confused me was that this feature (Surface, auto update etc) was available in earlier Lite versions. I'll attach a screenshot just to be extra clear about what I mean.
In the work I do on a daily basis, I rarely use FP and so far Lite version has been adequate for my needs. But should things change I would probably upgrade to Pro version.
François
« Reply #3 on: November 29, 2024, 10:53:24 am »
Hello, I've got the same problem. I can't add a new surface. Surface list is grey and disable.
I've got the lastest and Pro version  1.6.1 Max 2024.
