Forest Pack => Forest Lite => Topic started by: ammz.ray on September 03, 2013, 02:03:13 pm
Hello All,
the forests in my file move away from their centre all the time and misplaces on its own everytime i save my file.
The copies and instances also behave same and sometimes the forests do not render at all.
I am Using Max 2012 and Vray 2.40
does someone face a similar problem??
Can someone come up with a solution.
Ammz
What Forest version do you use ? Are the Forest objects in "Generate" or "Custom Edit" mode ?
If you have a scene that we can check, please send it to support@itoosoft.com.
About the rendering issue, this is a typical problem of some warez Forest Pro versions (that obviously we don't provide support). If this is not the case, please send us your scene for checking.
