Author Topic: Scattered object rotating on Z axis - Original Animation Does not!?  (Read 15493 times)
wubba
Hi all.. just trying to get my head around this amazing & feature rich plugin!!!...
I'm simply trying to animate my blades of grass cluster which is a mesh from SpeedTree (non-animated)... Its is a single mesh that I have added a Noise & Bump modifier to 3/4 of the mesh via Soft Selection (The grass object is to appear swaying/moving very subtly in the wind...
...Though when applied to a Forest Pro object, the scattered objects are animated but not the way intended... Each object rotates on its Z axis as if you it was spinning perioically in a 360 degree motion (its following the animated keyframes but not as the original grass object!?
What am I doing wrong!?.. anyone anyone
Cheers in advance!!!
Re: Scattered object rotating on Z axis - Original Animation Does not!?
« Reply #1 on: January 22, 2019, 08:05:20 am »
we cannot provide support in this Lite part forum. You should use an account with permissions to the Forest Pro(that is only for our customers) forum.
Thanks for your understanding.
wubba
« Reply #2 on: January 25, 2019, 03:11:34 am »
Unfortunately I cannot afford your amazing plugin as I'm purely a hobby enthusiast.. though if i was working within the industry, I would not hesitate in investing!!!..
Anyway I figured it out... Not exactly sure what caused it. But by persistent testing & rebuilding the forest objects for both trees & grass, I was able to get it animated the way intended!
« Reply #3 on: January 25, 2019, 07:58:02 am »
Great! Practice makes perfect.
