Author Topic: grass at boundary problem.  (Read 10422 times)
zahidhasan
« on: January 29, 2013, 01:00:55 pm »
hi everyone.my question is about Grass.
i usually use a 1' dia grass chunk to fill my lawn. but when i have narrow corners i want to use a second 2" dia smaller chunk to fill the corners and the edges .
is there a option so i can use both so that smaller chunk fills edges and critical small areas.and i don't want to cross the boundary spline in any way.
masking or material id seems too time consuming for repeated projects.
do you guys have a simpler solution.
zahidhasan
Re: grass at boundary problem.
« Reply #1 on: January 29, 2013, 01:18:55 pm »
i found a detail discussion here. :-)
http://www.itoosoft.com/forum/index.php?topic=1105.0
