Author Topic: Huge issue with 3.62  (Read 14881 times)
mumle
« on: December 19, 2011, 12:54:01 pm »
At my work we use 3.62pro and max12. At my latest project I have had to use an old scene with was made in max10 (can't remember which version of FP was used but properly the lastest at the time).
I the scene I had lots of grass (made using one FP-system in another). Now when I render the same scene there is almost NO grass at all... Do you have a quick fix for this? I have already wasted a weekend of rendering of something there aint useable...
Sorry for writing in this part of the forum, but our licens is not linked to my account.
Just a sidenote. It looks pretty correct in the viewport, but when it renders like 99% of my grass is missing.
« Last Edit: December 19, 2011, 12:57:47 pm by mumle »
Re: Huge issue with 3.62
« Reply #1 on: December 19, 2011, 01:08:02 pm »
But what is the state of the Forest objects ? Can you edit them or is it a rendering issue ?
mumle
« Reply #2 on: December 19, 2011, 01:12:19 pm »
Do you have an email I can send an example to?
« Reply #3 on: December 19, 2011, 01:23:17 pm »
Yes, you can send it to support@itoosoft.com.
Please, include also a new fresh scene with a default Forest object on it. We can use it to verify your configuration.
« Reply #4 on: December 19, 2011, 06:31:29 pm »
Thanks for the files. I just check the scene but everything seems correct, it renders fine as well.
What version of VRay do you use ? Here we have VRay 2.20.01.
mumle
« Reply #5 on: December 20, 2011, 10:40:43 am »
We use 2.10.01.
it renders correctly for me, but only if I collapse the "grass-system" to a mesh. So instead of distrobuting another FP-system it uses a mesh.
« Reply #6 on: December 20, 2011, 11:02:17 am »
Probably the FP objects with grass patches are generating instances instead a mesh, although the Display->Render mode is correct.
We cannot reproduce the problem here, but i will make some tests. Meanwhile, please use the collapsed meshes as Custom objects.
mumle
« Reply #7 on: December 20, 2011, 11:12:10 am »
I can see from the picture you posted you get the same problem as me, there are supposed to be 100x the amount of grass... I will post a picture shortly.
mumle
« Reply #8 on: December 20, 2011, 11:28:30 am »
From your picture it looks like you get the same error as me... I have attached a picture of how it is supposed to look.
« Reply #9 on: December 20, 2011, 05:26:21 pm »
Ok, it taked a while but i have found the problem:
The grass patches have Collisions enabled, so they are generating at render time much less items that you can see on the viewport. Turning off Collisions and adjusting the density should fix it.
mumle
« Reply #10 on: December 23, 2011, 10:25:42 am »
Thank you, must have changed in the later versions since i made the original scene.
