Forest Pack => Forest Lite => Topic started by: denfound on February 28, 2013, 03:45:46 pm
Hi Itoo software guys ! and thank you for your great product :)
Is there away to install forest on the network and share the installation between the other computer ?
is it possible to use 3rd paty plugin path in max ?
Is possible, although is not recommended in most cases as Forest Pack plugins has files dependencies that should be meet to work propertly. In this page we detailed all needed files and registry keys:
http://www.itoosoft.com/forestpack/reference/install.php (http://www.itoosoft.com/forestpack/reference/install.php)
If you wish to automate deploy of the software in your network the installer support unattended installations, use ForestPackPro.exe /? to see the parameters.
Thank you for your answer i will investigate further :)
