Forest Pack => Forest Lite => Topic started by: BP2759 on July 23, 2015, 05:17:28 pm
Title: Issue with 2 plane or 3 plane billboard plant
Post by: BP2759 on July 23, 2015, 05:17:28 pm
I made a dense forest with trees touching slightly, as trees do in forest.  But when I change the template type from a one plane billboard tree to 2 plane or 3 plane it will not show the change unless I change the Distribution unit size large enough that the trees will not touch. I do not remember this being a issue in past version.
I have version 4.3.6
Can this be fixed?   Or should I just make multiple version of the forest to overlap to get a dense look.  Weird Bug.
Title: Re: Issue with 2 plane or 3 plane billboard plant
Post by: iToo on July 23, 2015, 06:00:04 pm
Probably the geometry exceeded the Display->Viewport->Adaptative (http://docs.itoosoft.com/display/FORESTPACK/Display) limit, and Forest is using the default proxy mode (one plane).
It should work fine on render, or set Display->Mesh mode if you want to see the result on viewport.
