Author Topic: problems scattering with corona render  (Read 22071 times)
lv3droom
« on: October 31, 2017, 10:05:42 am »
I'm using forest pack pro version 5.3.0
With big grass area, i can scatter custom object by Forest oject ( for example : i make a small area of grass with Forest01, then make Forest02 to scatter Forest01 as an custom object in big area).
The problem is when i render with Vray everything is fine, but with Corona render it did not show anything.
Does anyone know how to fix it ?
Thanks.
Re: problems scattering with corona render
« Reply #1 on: October 31, 2017, 10:50:21 am »
The Render mode for the "nested object" should be changed from Automatic to Meshes under the Display roll-out. That should fix it.
« Last Edit: October 31, 2017, 10:53:21 am by Michal Karmazín »
lv3droom
« Reply #2 on: October 31, 2017, 11:07:51 am »
I did but it doesn't work !
lv3droom
« Reply #3 on: October 31, 2017, 11:13:48 am »
Here with Vray everything fine !
« Reply #4 on: October 31, 2017, 11:39:24 am »
The Meshes Render Mode should be set just for the "inner" object (001 in your case). The "main" Forest object (002) should be working in the Automatic Render Mode.
lv3droom
« Reply #5 on: October 31, 2017, 11:45:50 am »
Yeah can fixed it!
Thanks for your tip !
