Author Topic: Make objects not intersect with surface  (Read 10504 times)
tonneti
« on: May 25, 2012, 06:53:28 pm »
Can i set Forest PRO in one way that the teapots are not intersecting with my terrain?
Im using MultiScatter and think that this is not possible so maybe is time to move to FP, since all the good comment over the www may be in right direction... :)
p.d.: i know this is F Lite forum but since i cant post to Pro forum... :P
http://imageshack.us/photo/my-images/39/ms1xq.jpg
Re: Make objects not intersect with surface
« Reply #1 on: May 25, 2012, 07:51:13 pm »
It can be done with some manual work:
1) Convert the surface to Editable Poly.
2) Select the horizontal edges and use "Create Shape" to convert them to splines.
3) Create a closed spline for each floor of the terraces.
4) Assign the splines as include Areas (you can attach all splines together as well).
5) Set the Area Boundary Check mode to "Size". In this way, Forest uses the full size of the teapots for the boundary checking, not only the scattering position.
6) Assign the surface in the Surfaces rollout.
You would test the procedure using Forest Lite. The items will not be positioned at the right elevation, but you can see if the distribution is correct for your scene.
« Last Edit: May 25, 2012, 07:54:12 pm by iToo »
tonneti
« Reply #2 on: May 26, 2012, 12:55:37 am »
Mmmm so no "automatic" mode :), well i will try with this approach, but is considerable work wor great terrains...
Thanks for the detailed and fast answer!!
