Forest Pack => Forest Lite => Topic started by: monomon on January 23, 2018, 11:33:17 am
Hi, I am trying to set a ForestPack instance's distribution map with a python script in 3ds max and I am having problems with it.
First, I create a MaxPlus.Bitmap in which I load an existing file from disk. Then, a MaxPlus.BitmapTex and set my bitmap on it. Finally, I set this BitmapTex on the "distmap" property of Forestpack.
When the script completes, the forest appears empty (though the distmap button in the sidebar indicates my distmap).
If I now manually click to reselect the map from the material editor it works! ???
I am not sure what changes when I do this, like some weird conversions or setting missing properties... or do I just need to trigger some kind of update?
Here's example code:
BMM_GRAY_8 = 3 # 8-bit grayscale bitmap.
# Bitmap open mode flags
BMM_NOT_OPEN = 0
BMM_OPEN_R = 1
BMM_OPEN_W = 2
node_name = "forest_flowers"
conf = {
"width": 32,
"height": 32,
"name": "bla" + str(random.randint(1, 15000))
def create_bitmaptex(bm, conf):
bt = MaxPlus.Factory.CreateDefaultBitmapTex()
bt.SetBitmap(bm)
bt.SetFilterType(0)
# wtf, isUIAction has to be true for Display to work...
bt.SetMapName(bm.GetStorage().GetBitmapInfo().GetName(), True)
return bt
def load_bitmap(bmpath, conf):
width = conf["width"]
height = conf["height"]
storage = MaxPlus.Factory.CreateStorage(BMM_GRAY_8)
info = storage.GetBitmapInfo()
info.SetWidth(width)
info.SetHeight(height)
info.SetName(conf["name"] )
info.SetPath(bmpath)
info.SetGamma(2.2)
info.SetBitmapType(BMM_GRAY_8)
storage.Allocate(info, BMM_OPEN_R)
bm = MaxPlus.BitmapManager.Load(info)
bm.SetStorage(storage)
return bm
def add_to_current_library(mat):
MaxPlus.MaterialLibrary.GetCurrentLibrary().Add(mat)
try:
forest_pack = MaxPlus.INode.GetINodeByName(node_name)
# use one of the forestpack distmaps for example
bmpath = os.path.join(
"C:/",
"Program Files (x86)",
"Itoo Software",
"Forest Pack Pro",
"distmaps",
"images",
"spread2.bmp"
print("bitmap path", bmpath)
bm = load_bitmap(bmpath, conf)
print("bitmap", bm)
bm.Display()
bt = create_bitmaptex(bm, conf)
print("bitmaptex", bt)
add_to_current_library(bt)
forest_pack.Object.GetParameterBlock()\
.GetParamByName("distmap")\
.SetValue(bt)
MaxPlus.ViewportManager.ForceCompleteRedraw()
# The value of distmap is now of type MaxPlus.Texmap
print("distmap value", forest_pack.Object.GetParameterBlock()\
.Value)
except Exception as e:
traceback.print_exc()
As an aside, initially I wanted to make this work with procedurally generated bitmaps, but that failed worse - manual reselection did not fix it, (I am guessing) because the bitmap's in-memory storage doesn't persist.
I'm sorry, but Lite support is limited, as described here:
https://forum.itoosoft.com/forest-lite/forest-pack-lite-support-policy/
Thanks for your understanding.
