		Forest Pack => Forest Lite => Topic started by: MancDan on June 08, 2016, 10:59:03 am
				We've been using Forest Pack for a little while now but the tree's we tend to use lack transparency. They are too solid giving a solid unnatural look.
 Common tree 5 for example.
 I've instanced the material from the forest pack UI into the material browser attempting to edit the material by throwing a transparency map in there, but it doesn't seem to be changing anything! I've managed to place a leaf bitmap on to the leaves where previously lay a ForestColour map and this now shows in my test renders, so my changes to the material are having some effect on the outcome - just not the translucency map!
 Also, when placing a new leaf texture in the diffuse slot, is there anyway to map this correctly? I've found placing a UVW map onto the Forrest object using face mapping helps, but I'm not too sure how you map both the leaves and trunk/branches independently. Face mapping the entire tree object of course alters the mapping of the bark material.
 Any help here would be greatly appreciated! :)
 (I should add we are using ForestPack Pro 4.3.7)
				I've figured out how to edit the mapping for both the bark and leaves, editing the forest template! :)
 Now how to add some transparency to the the leaves!?
				Hi, to post questions about Forest Pro please use the Pro forum (http://forum.itoosoft.com/index.php?board=5.0). You can see our support policy for Lite version here (http://forum.itoosoft.com/index.php?topic=2012.0).
 Thanks.
