Author Topic: anim sequence (only cam and sun moving) 4 frames some forestpack objects dissapp  (Read 9239 times)
filip
vray GPU, rtx or cuda same behaviour, same with the latest nightlie, updated the FP to latest as well (one version up), recommended drivers, max 2024 updated to latest... on which side is the issue chaos or itoo? Should I send my file somewhere? ps: scene is quite heavy but stat says around 12gb from 22 available gpu ram used. PS: the objects that are not updating are the ones used as vraydistancetex objects. PS2: converting FP object to static mesh seems to work.
« Last Edit: January 25, 2025, 10:08:40 am by filip »
Hi Filip,
I'm sorry to hear that you're experiencing these difficulties. First, let me mention that you should avoid using the Camera - Distance Falloff feature when rendering walk-through animations. This feature can cause sudden appearance or disappearance of items due to changes in camera distance during motion, as stated in our online reference guide.
I would recommend switching to the Custom Edit mode to see if there's any difference. Also, please use the Surface > Place Items button and try disabling the Surface > Non-Image modes - Link to surface.
If that doesn't fix it, please feel free to send us your scene and we'll check it. Thank you in advance.
Thank you in advance for any further comments you can share about this issue with us or our user community, in case other users encounter similar problems.
