Forest Pack => Forest Lite => Topic started by: fransblok on June 22, 2015, 05:14:03 pm
Title: Wind turbines - animation doesn't work
Post by: fransblok on June 22, 2015, 05:14:03 pm
I am trying to make an animation of wind turbines at sea. I've created a forest with the blades of a turbine as custom object. The blades are an object imported from Autocad.
I've animated the blades to rotate 360 degrees. In the animation rollout I've checked "follow geometry"; I've also unchecked "animate only at render time."
But the blades in the forest won't move.
Any ideas what could be the reason?
thanks in advance
Title: Re: Wind turbines - animation doesn't work
Post by: Michal KarmazĂ­n on June 22, 2015, 05:45:46 pm
Quote
"I've animated the blades to rotate 360 degrees."
Not sure, how the animation is done, but I would suggest you to apply to your Custom Object the XForm modifier and animate that (instead of animating Position/Rotation/Scale controller of the Custom Object as Forest takes control over it during scattering calculation).
Hope that helps.
Post by: fransblok on June 23, 2015, 02:11:05 pm
That certainly helps! I've applied the X-form modifier en now my turbines are rotating. Thanks!
