Author Topic: [SUGESTION] Material color tint probability curve  (Read 5565 times)
Viz3D
    • Viz3D
« on: February 07, 2022, 05:19:49 pm »
is it possible that something like shown in the attached picture will be implemented in the future?
Regards
Re: [SUGESTION] Material color tint probability curve
« Reply #1 on: February 09, 2022, 02:53:44 pm »
Thanks for the suggestion. Rather than add more components to the UI, I would instead recommend using a Custom Gradient in the Tint Map slot. That way you could change the probability by adjusting the gradient quite easily as well as using it for several other interesting effects.
I hope that helps,
Viz3D
    • Viz3D
« Reply #2 on: February 09, 2022, 02:58:29 pm »
You are right. I didn't think of it thoroughly.
Thanks for the heads up!
« Reply #3 on: February 09, 2022, 03:04:11 pm »
Thanks for the question! Actually, I hadn't thought too much about this myself, I think it'll make an interesting topic for a quick tip video.
Best,
Viz3D
    • Viz3D
« Reply #4 on: February 09, 2022, 03:10:30 pm »
I guess this  will help other users as well. Glad that this was an inspiration for a quick tip.
Regards!
« Reply #5 on: February 09, 2022, 03:16:22 pm »
I've already started :)
