Author Topic: Animable ON/OFF  (Read 2826 times)
RealViz
    • RealViz
Animable ON/OFF
« on: January 21, 2020, 08:34:23 am »
Is it possible to turn FP on and off in animation? Thanks
Re: Animable ON/OFF
« Reply #1 on: January 21, 2020, 08:57:16 am »
No, You can only adjust its visibility using standard max methods- like animating Objects visibility setting:
RealViz
    • RealViz
Re: Animable ON/OFF
« Reply #2 on: January 21, 2020, 09:02:57 am »
Yes, this solution also occurred to me. Unfortunately, in this case it is actually only hidden and the FP is still in memory and all preprocesses are in progress. We will continue to shut down manually. Thanks
Re: Animable ON/OFF
« Reply #3 on: January 21, 2020, 11:49:29 am »
You can use another 3ds max standard tool - Sequencer. That should save memory resources.
(C) Paul 2020
RealViz
    • RealViz
Re: Animable ON/OFF
« Reply #4 on: January 23, 2020, 07:50:27 am »
Yeah. Good idea. Sequencer is the solution. Thanks!
