Author Topic: [Solved] plant trees with add button, disappear when i leave sub-object mode....  (Read 5890 times)
KG4241
Hello !
i'm very confused...
i plant some trees manually, scale them individually, spend hours to prepare my scene vegetation.
I also used the general seed to change them (very nice feature)
Then, then i leave the sub-object mode Almost ALL trees disappear, only 3 or 4 trees remaining.
the more frustrating : when i activate again the sub edit mode, all trees reappears !
but if i uncheck sub-object mode, they disappear again....
the problem is that i MUST leave the sub-object mode if i want to select another object in the scene....
I'm inmiddle of rush job, can you please tell me what i'l doing wrong ? (i use the latest 4.3.6 version with 3dsmax 2015 SP3)
Thanks in advance,
« Last Edit: February 14, 2015, 08:47:22 pm by KG4241 »
KG4241
Forget about it, i found out !
i had the "limit to visibility" checked.
Sorry ! i'm happy again !
