Author Topic: Follow Displace Surface (VRay)  (Read 3168 times)
MarckPX2
« on: January 14, 2022, 05:56:15 pm »
this is a well known problem which I thought was solved by now.
Anyway, I followed this guide:
https://www.itoosoft.com/tutorials/scattering-on-displaced-geometry
However, applying the effect only causes the objects to be adjusted overall in height.
The height differences of the (displ map) surface are not adopted.
What am I missing here?
Cheers
Re: Follow Displace Surface (VRay)
« Reply #1 on: January 14, 2022, 08:39:38 pm »
Can You share the scene?
Working fine for me.
MarckPX2
« Reply #2 on: February 07, 2022, 10:12:52 am »
Hey Dragan,
thanks for your reply.
Please find attached the corresponding scene.
best
Marck
« Reply #3 on: February 07, 2022, 11:06:06 am »
Now, It is not working for me either  :o
I don`t know if my test was done on some previous version of FP but it could be at least one or maybe two before 7.3 because I try to keep up.
MarckPX2
« Reply #4 on: February 07, 2022, 12:01:55 pm »
Well, that is unfortunate.
Thanks for trying, though.
This one was done in FP 7.2.1
I will give it another try using the latest update 7.3.0.
UPDATE:
The effect is also not functional in version 7.3.0 (at least not on my workstation in 3ds max 2022)
Any ideas?
UPDATE 2.0:
It works.
It depends on which type (2D / 3D) of the VRayDisplacementMod is used.
However, in order to use a procedural map, it must be set to explicit map channel.
« Last Edit: February 07, 2022, 04:38:36 pm by MarckPX2 »
