Author Topic: 1.4 server is stopped  (Read 6331 times)
Rhodesy
« on: March 16, 2020, 11:31:24 am »
Hello. I'm looking at how we can borrow licenses from the office where we have the license server. Looks like its possible but so far we are not having any luck. One reason for this though could be that the 1.4.0 license server we are running says the server is stopped in yellow. When we have looked at this befroe its been fine and says its runnng in green. However all our computers are connected and working fine with FP and RC and the licenses are listed and active. so I'm not sure why its saying its stopped. Start server and refresh dont do anything. The hardware ID is listed and it says its connected at the bottom.
Any ideas?
Also do you think this is why inputting the IP of the server isnt working for borrowing the license?
Re: 1.4 server is stopped
« Reply #1 on: March 16, 2020, 11:35:51 am »
Seems like You have more than one license server in the network.
You can check the log and see the messages. if You still need further assistance please contact us using this form and we will continue the conversation.
Rhodesy
« Reply #2 on: March 16, 2020, 11:51:50 am »
Ah Ha! Yes my old workstation which is now a render node has it still installed and I can see its running there. I will uninstall it off that machine so its only coming from my current workstation and give that a go. Thanks!
Fingers crossed that will help fix the license borrowing. Sounds like its as simple as just manually entering the server IP. Then if I disconnect from the network after should that be enough to run FP/RC without being on a network?
Thanks again.
