Author Topic: optimized materials and override  (Read 5790 times)
barry john
  • Barry John
    • 3d digital studio
« on: January 21, 2013, 10:40:29 pm »
I have optimized materials and then within the forest color turned on override and then changed the gradient colours, which was ok but i decided that i prefered the scene without the override and although i have switched the override off the trees are still using the gradient, do i need to do something else to revert back?
Re: optimized materials and override
« Reply #1 on: January 21, 2013, 11:22:42 pm »
If Override is off, Forest applies the tint color defined in the Material rollout of the Forest object.
To disable it, just set the range of Material->Color Tint->Random Strength to zero: http://www.itoosoft.com/forestpack/reference/refmaterial.php
Probably the tint effect was not visible before, because all tint modes require to use Forest Color or Forest Material (which didn't exist before applying the material optimizer).
