Author Topic: 3D objects creation setting  (Read 4854 times)
Fer
« on: May 06, 2021, 09:19:29 pm »
Doing some tests with my farm I realized that there are some elements on the Forest library (stumps and rugs specifically) that have the 3d object creation dialog enabled, and if the option chosen is XRef to library then those elements won't be rendered if I use for example vray distributed rendering since the path to those objects are located on my local user folder and not on a network path. Is this a mistake and those elements should always be merged into the scene or Am I missing some configuration where I can get those elements to be on a network path?
Re: 3D objects creation setting
« Reply #1 on: May 07, 2021, 08:07:51 am »
Hi. Yes it is inconsistency from our side. Thank You for reporting
Just make sure to use merge option and it should work.
Fer
« Reply #2 on: May 07, 2021, 05:59:15 pm »
Gotcha, thanks for the reply!
