Author Topic: 3ds Max 2021, FP 6.3.0 Not rendering  (Read 5178 times)
OS3519
« on: May 14, 2020, 04:46:47 pm »
Hi. I've been asked to prepare/optimize a big scene coming from an archviz company that needs to render a video out of it using Corona.
No matter what I do, I cannot render one single FP object, as it comes out empty.
All the FP objects are visible in the scene, and if I try to recreate some of them using the same assets it renders perfectly fine.
I've explored all the possible causes but came out without a solution.
I need urgent assistance with this issue, as the deadline for the project is really tight.
The files handed to me were done in Max 2019 and I guess some older Forest Pro version.
I'm working with the latest official release and Max 2021.
Thank you.
https://www.dropbox.com/s/rwxjn72yyxcqrve/Forest_Clump_Test.zip?dl=0
Here's the link to a small test file in Max 2021 using a super simple FP object.
OS3519
Re: 3ds Max 2021, FP 6.3.0 Not rendering
« Reply #1 on: May 14, 2020, 07:45:14 pm »
Nevermind. I solved the issue. Somebody set the render mode to "meshes", and although it renders fine in V-ray, it doesn't in Corona. Setting it to default "automatic" mode solves the problem.
