Author Topic: How to quickly select objects from Forest Pack?  (Read 3452 times)
EstebanAV
« on: July 11, 2023, 04:09:59 am »
Hi! While working with FP, I was looking for a way to put some order and organization to a heavy scene I own.
So, is there a quick and practical way to only select the objects/geometry from a forest or even forest set object? Instead of looking for them in scene explorer and pick them up manually?
I was imagining to be able to select these objects and put them inside a layer for example. Especially if I'm not using a library preset. What I've found about this topic is the other way around. Creating a forest object from selection but I actually need the opposite without instantiate. Maybe a silly question but I haven't found the answer. If it doesn't exist, maybe could be an improvement? Thanks in advance.
« Last Edit: July 11, 2023, 04:13:17 am by EstebanAV »
Re: How to quickly select objects from Forest Pack?
« Reply #1 on: July 11, 2023, 09:31:02 am »
You should have a quad menu option to select dependencies - You can either choose to select geometry, surface, area, or all the dependencies. To select multiple entries, you can hold down Control.
I hope that helps,
EstebanAV
« Reply #2 on: July 11, 2023, 06:34:45 pm »
This is pure gold! Phew... Now I kinda feel bad for not seeing this before. Especially if it's the same thing to select from a railclone.... douh!
Thanks a lot Paul. Cheers
ritoo
« Reply #3 on: July 14, 2023, 09:38:09 am »
Doh! Moment for me! When it was added?
« Reply #4 on: July 14, 2023, 12:03:58 pm »
It has been available for a long time.
According to my release notes, it was added to Forest Pack 4.
