Author Topic: VRay IPR and Custom Edit  (Read 11777 times)
Nawras Ryhan
« on: March 01, 2023, 03:41:45 pm »
Hello guys,
I have a very annoying problem with FP custom edit while working with IPR .
the problem is that all the items will disappear from the viewport ( still show in the render) and even if I press Ctrl +A to select everything I can't select them till I stop the IPR .
I'm using 3ds Max 2023.2 , VRay 6.1 and of course FP latest update too (8.0.9)
let me know if you need any further info .
Thanks in advanced.
Edit:
I've searched the forums and it seems that this issue is a well-known with VRay IPR and FP.
could you please share an update about if it is possible to fix in any near future?
https://forum.itoosoft.com/forest-pro-(*)/ipr-fp-7-4-3/msg35212/#msg35212
« Last Edit: March 01, 2023, 04:00:53 pm by Nawras Ryhan »
Re: VRay IPR and Custom Edit
« Reply #1 on: March 03, 2023, 12:34:34 pm »
I'm checking this and making some changes.
If there are not problems, Custom Edit with IPR should work correctly for the next Forest update.
Nawras Ryhan
« Reply #2 on: March 03, 2023, 03:52:55 pm »
That would be great !Thank you !
I'm using the workaround that's mentioned in the other thread (changing from Small Dot to Large dot or the opposite) .
I couldn't find the Maxscript command for this option using "Show $" , is it accessible ?
« Reply #3 on: March 04, 2023, 08:51:00 am »
This specific value is not accesible from Maxscript, because is not a parameter of the Forest object (it's a global config value, stored at 'forestpack.ini').
But you can change any other parameter, for example Cloud Density: '$.cloudens = 50'
Nawras Ryhan
« Reply #4 on: March 04, 2023, 01:16:29 pm »
That would do as a workaround for now , Thank you !
Nawras Ryhan
« Reply #5 on: March 14, 2023, 09:37:13 pm »
I just wanted to say that I've installed the new update (8.1.0) and IPR is working perfectly smooth without any bugs while I'm  in edit mode!
I pretty happy with the new experience and it will make my life much easier for the current project I'm working on .
Thank you for the quick update !
Nawras.
« Reply #6 on: March 15, 2023, 08:02:57 am »
Thank you for the feedback ! I'm glad you enjoy the changes.
ezmerel2
« Reply #7 on: March 16, 2023, 10:44:54 am »
Wow,
Being able to edit while on IPR again after such a long time of FP disappearing on the viewport is just.... amaaazing...
Big update for me here.
Many thanks.
