Toggle navigation
Login
Register
Forest Pack
Forest Pro (*)
HELP! 4.0.3 cannot recognize a box 1m x 5m in 3ds max 2012!!!!!!
« previous
next »
Print
Pages: [
1
Author
Topic: HELP! 4.0.3 cannot recognize a box 1m x 5m in 3ds max 2012!!!!!! (Read 4474 times)
Morpheus
Newbie
on:
April 19, 2013, 06:23:29 pm »
I create a solid box in 3ds max 2012 1m x 5m.
Then when I go to select it with Forest pack 4.0.3, I see
only an "F" icon and no forest pack objects!!!!
Why?
I do something wrong or this is a bug?
thank you.
Last Edit: April 19, 2013, 06:33:57 pm by kseskier
Logged
Administrator
Hero Member
Re: HELP! 4.0.3 cannot recognize a box 1m x 5m in 3ds max 2012!!!!!!
Reply #1 on:
April 19, 2013, 07:04:18 pm »
Please, check the information window at General->Forest Stats.
If the error is "No visible items", probably the density of the Distribution Map is too low to create any item. In this case, adjust the X/Y Density values.
Logged
Morpheus
Newbie
Reply #2 on:
April 19, 2013, 08:18:46 pm »
Carlos I did what you said but I found the solution...
For small surfaces I create simple lines and I pick them
to put forest pack instead of surfaces or solids.
Seems that sometimes for no reason cannot apply small
surfaces or solids, so the solution is to create lines/polylines....
thank you for your immediate answer.
Forest pack is the BEST program I ever used...
Logged
Print
Pages: [
1
« previous
next »
Forest Pack
Forest Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
