Author Topic: ho wto setup area scale curve to match this shape  (Read 4513 times)
lukx
    • lukxCGI
« on: September 24, 2023, 03:18:20 pm »
I'm trying to create brush with forest pack and I'm tryin to create it's shape with area scale but can't match it. I will fdd box the main spread just need smooth getting shorter the bristles.
Re: ho wto setup area scale curve to match this shape
« Reply #1 on: September 25, 2023, 10:07:10 am »
Hi Lukasz,
Using the bundled "Lean Out (Include)" effect together with the Scale Fallouf feature seems to do the trick. Please find attached a sample scene (230925_leanOutSampleScene_iToo.max) showing this possible setup. I hope that helps.
lukx
    • lukxCGI
« Reply #2 on: September 25, 2023, 05:46:10 pm »
Thank you Michal!
« Reply #3 on: September 26, 2023, 09:04:48 am »
Hi Lukasz,
You're welcome. I'm glad to hear that it helped, and I wish you the best results. ;)
RealViz
    • RealViz
« Reply #4 on: September 26, 2023, 10:52:32 am »
Or you can curve the distribution area, which is hidden inside the brush handle anyway.
