Author Topic: TGtlink.cpp Error  (Read 4440 times)
mitviz
    • mitviz
TGtlink.cpp Error
« on: March 15, 2020, 12:17:17 pm »
anyone know what can cause this kind of error? see the attached
Professional architectural renders
Re: TGtlink.cpp Error
« Reply #1 on: March 16, 2020, 08:36:38 am »
Hi, this is an initialization error one of the libraries used by Forest.
I would suggest a reinstallation of the plugin using admin privileges (setup program->right click->run as admin).
What Forest, 3DS Max and Windows versions do you use ?
mitviz
    • mitviz
« Reply #2 on: March 18, 2020, 01:17:03 am »
shoot ok, am using max 2015 and windows 10 pro
« Reply #3 on: March 18, 2020, 09:13:12 am »
We just tested Forest Pack 6.2.4 in 3DS Max 2015 SP4, and everything seems correct.
Please, try this:
1.- Delete the files ForestQt.dll, QtCore_Itoo_4.dll, QtGui_Itoo_4.dll, QtXml_Itoo_4.dll and QtSolutions_MFCMigrationFramework-Itoo.dll from the 3DS Max root folder.
2.- Reinstall Forest Pack with admin privileges (as described in my previous post). Please also be sure to use the latest version.
3.- Check if the files listed at step 1 are copied in the 3DS Max folder, after the reinstallation. If so, try to use Forest and tell us if it worked.
mitviz
    • mitviz
« Reply #4 on: March 18, 2020, 09:16:00 am »
Hi, it seems to be working with just the admin installation so far in the same scene, i will know later today after i have checked a few more scenes where i had this issue, thank you!
