Author Topic: Problem with mesh  (Read 6626 times)
Martin
Problem with mesh
« on: July 02, 2013, 05:44:45 pm »
HI. I have made a plane and convertet the plane to a mesh and used the paint deformation in 3ds max to create hills and so on.
When I render with a forest preset  turned on, nothing is showing.
When I create a normal plane and then assign a forest preset it is working fine.
What is the problem.??
Martin
Re: Problem with mesh
« Reply #1 on: July 02, 2013, 06:35:31 pm »
I found out why... It is because the mesh is -0,7 meter below 0,0,0 why is that a problem.??
« Reply #2 on: July 02, 2013, 07:45:22 pm »
The position of the mesh should not be a problem. Please, post a test scene and we will check it.
Martin
« Reply #3 on: July 02, 2013, 09:24:11 pm »
I try to isolate the mesh and forest objects. and now it renders fine. so it must be a issue with memory in the scene.
I have quite many objects in scene.
Martin
« Reply #4 on: July 02, 2013, 10:14:19 pm »
I have solved the problem..
It was a very heavy texture which caused the problem. Everything is fine now..
Tx,
« Reply #5 on: July 02, 2013, 10:28:43 pm »
Ok. I'm glad the problem is solved.
