Author Topic: Making leaf wall problem uv and xy mod does not work!  (Read 4880 times)
GJ4477
« on: April 15, 2015, 11:55:39 am »
hello
I m trying to make leaf Wall in different shapes. I have a leaf to apply. And i have splines drawed in different shapes. when i create sphere or box model and apply forestpack choose my leaf and select uv mode it Works perfect. But when i put my custom draw spline which extruded and put into surfaces  it Show anything in uv mode. i change to xy mode and it only create scattering on top surface . I attach 2 screenshoot about it. PLease help me. I hope i could explain .
Re: Making leaf wall problem uv and xy mod does not work!
« Reply #1 on: April 15, 2015, 12:21:44 pm »
The UV mode requires defined UV coordinates. These are by default created for primitive objects (having the Generate Mapping Coords. option enabled), but when extruding splines you'll need to "map it" by yourself. I would suggest you to add the UVW Map modifier - the Face mode in this case should be fine. Hope that helps.
Kind regards,
