Author Topic: Edge mode, alpha problem  (Read 4153 times)
Dean
« on: April 16, 2015, 02:11:49 pm »
I have  a problem with the new edge mode. If you see the attachments, the edge is affecting the alpha, and other channels, in a bad way. It almost looks like a mix between the normal mode, and edge mode, and the difference is being made black / affecting the channels.
Does anyone know what might be happening?
Dean
Re: Edge mode, alpha problem
« Reply #1 on: April 16, 2015, 03:18:13 pm »
These artefacts could be caused by exceeding V-Ray's transparency limit (as mentioned in this related post). There are two possible ways, how to avoid that troubles:
a) Use lower density values, increasing Distribution Map -> Density X/Y Size.
b) Under V-Ray render settings, increase Global switches -> Max transp. levels (default value is 50). Sometimes may be necessary to modify Secondary rays bias also.
Hope that helps.
Dean
« Reply #2 on: April 16, 2015, 03:55:42 pm »
Thanks, the max transparency seems to have sorted the problem. It might be worth adding that to the end of the video tutorial, or adding some notes, as I would have never thought about tweaking the max transparency.
Anyway, thank you!
Dean
