Author Topic: 4 identical forests on 4 different surfaces  (Read 4037 times)
in3des
« on: February 19, 2020, 01:11:07 pm »
One small question - hope there is some quick solution (without wiring many parameters manually).
I have 4 different surfaces - need to populate 4 forests on top of those.
Ideally each forest should be an instance but targeted to a different surface, so if I change any option (density, scale, etc.) all changes spread instantly to every surface.
Thanks!
in3des
Re: 4 identical forests on 4 different surfaces
« Reply #1 on: February 19, 2020, 01:15:13 pm »
I think I would need some parent forest object so settings affect all other child objects. (if that possible)
« Reply #2 on: February 19, 2020, 01:27:45 pm »
quick solution is to add all those surfaces to to the surfaces list in Surfaces rollout:
in3des
« Reply #3 on: February 19, 2020, 01:41:30 pm »
well... that was not exactly what I'm trying to solve )) sorry for long explanation
another case - 4 surface instances + 4 cameras (some kind of a setup)
forest generated elements must be 100% same on each surface - so it looks 100% identical if render those 4 cameras
in3des
« Reply #4 on: February 19, 2020, 01:47:35 pm »
quick example
2 plane instances
I need forest elements on plane2 look same as on plane1
and make settings changes in one place, so they affect both planes
« Last Edit: February 19, 2020, 01:53:07 pm by in3des »
« Reply #5 on: February 19, 2020, 01:58:30 pm »
Then wiring it is.
in3des
« Reply #6 on: February 19, 2020, 02:24:09 pm »
ok, got it.
Thanks for help! :)
« Reply #7 on: February 19, 2020, 02:39:47 pm »
And don't forget to assign same relative to surface origin for all ForestPack objects :
« Last Edit: February 19, 2020, 03:27:16 pm by Rokas »
in3des
« Reply #8 on: February 19, 2020, 03:28:20 pm »
Thanks a lot, Rokas!
didn't know about that.
in3des
« Reply #9 on: February 19, 2020, 06:00:38 pm »
potentially very cool script for multiple wiring...  ???
but it's too old and doesn't work (also tested for very simple objects)
http://www.scriptspot.com/3ds-max/scripts/multiwire
