Author Topic: convert grass to instances - issue  (Read 3723 times)
in3des
« on: August 08, 2016, 06:50:59 pm »
Just found out some issue when converting forest grass to instances.
Instances are not covering all surface, density is not enough. I tried to change point-cloud global&local density, but that not helps. (by default it is set to 50%, I put it to 100%)
Please help how to deal with that.
« Last Edit: August 08, 2016, 06:52:57 pm by in3des »
in3des
Re: convert grass to instances - issue
« Reply #1 on: August 08, 2016, 07:01:41 pm »
forest statistics says Forest generated 26K items
after instantiate tool I have 6502 items only.
« Reply #2 on: August 09, 2016, 08:39:33 am »
Hi, Forest Tools generates only visible items at viewport. It's a security mechanism to avoid create too much items.
Just set Display->Max.Items to 0 before applying Forest Tools. That disables the display limit.
in3des
« Reply #3 on: August 09, 2016, 11:40:43 am »
thank you!
in3des
« Reply #4 on: August 12, 2016, 03:19:11 pm »
I got additional question
Is there any way to convert forest to instances and keep border behavior?
otherwise it's useless to convert grass as it goes through all curb stones  :(
« Reply #5 on: August 12, 2016, 03:38:53 pm »
I guess you're referring to the Edge Boundary Checking mode. There is no "physical cut" performed while using the Edge mode (as this would be extremely resource demanding) - the "trimmed part" is treated by the render engine as a kind of Matte object internally (this way render engine ignores it for its calculations).
For further "instancing", I would suggest a slightly different work-flow described in our Grass Edges tutorial (where small & large clumps are mixed, while the Boundary Checking mode is set to Size).
Hope that helps.
in3des
« Reply #6 on: August 12, 2016, 04:25:12 pm »
good, thanks !
I remember this old one tutorial :) old but still very useful :)
