Toggle navigation
Login
Register
Forest Pack
Forest Pro (*)
6.1.1 Edge Mode and Position Problem
« previous
next »
Print
Pages: [
1
Author
Topic: 6.1.1 Edge Mode and Position Problem (Read 5545 times)
hubmer3
Newbie
on:
June 28, 2018, 03:35:51 pm »
Hy, i set up a simple scene with the updated version of ForestPack and i dont know what is wrong here....the Position isnt working
Edgemode also isnt working correctly with presets....
Max 2018 + vray 3.60.03
thx
Logged
Hero Member
Re: 6.1.1 Edge Mode and Position Problem
Reply #1 on:
June 28, 2018, 04:58:50 pm »
Hi, could You attach Your scene for us to check ?
Logged
amitgedia
Full Member
Reply #2 on:
June 29, 2018, 10:25:30 am »
Just a quick question have you checked the pivots, are they aligned centrally, sometimes its the pivots problem as well please check that and see if it works
Amit
Logged
hubmer3
Newbie
Reply #3 on:
July 11, 2018, 04:41:38 pm »
Hy, yes i checked the pivot point..... thx for the hint.
I think in an earlier version it worked....
@mod
the file is attached
thx phil
Last Edit: July 11, 2018, 05:18:03 pm by hubmer3
Logged
Hero Member
Reply #4 on:
July 13, 2018, 02:21:35 pm »
Regarding edgemode- ForestPack does not clip the geometry. RailClone does. Maybe You want to use it instead?
You can explode concrete block faces to be separate elements- then ForestPack will hide elements outside the area.
Regarding translation feel free to adjust it with offset parameters.
Logged
Print
Pages: [
1
« previous
next »
Forest Pack
Forest Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
