Forest Pack => Forest Pro (*) => Topic started by: hubmer3 on June 28, 2018, 03:35:51 pm
Hy, i set up a simple scene with the updated version of ForestPack and i dont know what is wrong here....the Position isnt working
Edgemode also isnt working correctly with presets....
Max 2018 + vray 3.60.03
thx
Hi, could You attach Your scene for us to check ?
Just a quick question have you checked the pivots, are they aligned centrally, sometimes its the pivots problem as well please check that and see if it works
Amit
Hy, yes i checked the pivot point..... thx for the hint.
I think in an earlier version it worked....
@mod
the file is attached
thx phil
Regarding edgemode- ForestPack does not clip the geometry. RailClone does. Maybe You want to use it instead?
You can explode concrete block faces to be separate elements- then ForestPack will hide elements outside the area.
Regarding translation feel free to adjust it with offset parameters.
(https://i.imgur.com/bE2Od0i.jpg)
