Author Topic: 6.1.1 Edge Mode and Position Problem  (Read 5549 times)
hubmer3
« on: June 28, 2018, 03:35:51 pm »
Hy, i set up a simple scene with the updated version of ForestPack and i dont know what is wrong here....the Position isnt working
Edgemode also isnt working correctly with presets....
Max 2018 + vray 3.60.03
thx
Re: 6.1.1 Edge Mode and Position Problem
« Reply #1 on: June 28, 2018, 04:58:50 pm »
Hi, could You attach Your scene for us to check ?
amitgedia
« Reply #2 on: June 29, 2018, 10:25:30 am »
Just a quick question have you checked the pivots, are they aligned centrally, sometimes its the pivots problem as well please check that and see if it works
Amit
hubmer3
« Reply #3 on: July 11, 2018, 04:41:38 pm »
Hy, yes i checked the pivot point..... thx for the hint.
I think in an  earlier version it worked....
@mod
the file is attached
thx phil
« Last Edit: July 11, 2018, 05:18:03 pm by hubmer3 »
« Reply #4 on: July 13, 2018, 02:21:35 pm »
Regarding edgemode- ForestPack does not clip the geometry. RailClone does. Maybe You want to use it instead?
You can explode concrete block faces to be separate elements- then ForestPack will hide elements outside the area.
Regarding translation feel free to adjust it with offset parameters.
