Author Topic: FPP 6.1.1 and VRay Next IPR  (Read 5619 times)
amitgedia
« on: August 21, 2018, 01:27:20 pm »
Just curious that why FPP doesnt work with IR
Will this be fixed in later versions or will it never work
I get an error when i try to do it
attaching the screenshot of it below
Amit
Re: FPP 6.1.1 and VRay Next IPR
« Reply #1 on: August 21, 2018, 02:17:51 pm »
Thank You for the file.
Disabling Slice option in deform tab seems to fix the issue.
amitgedia
« Reply #2 on: August 21, 2018, 04:06:58 pm »
Hi Rokas,
I hope we are not confusing ourselves with RC, is there a slice option in forest pack as well i didnt know that
Please enlighten
Amit.
« Reply #3 on: August 21, 2018, 04:30:40 pm »
I replied in wrong thread. I am sorry ;)
Regarding Your question:
Many of the parameters can be edited live with IPR running. There few exceptions- like loading new library assets.
But overall experience to adjust FP scatter should be running smoothly.
What exactly is not working for You?
amitgedia
« Reply #4 on: August 21, 2018, 04:44:31 pm »
Loading new library assets is not working, havent tried changing other parameters though. I was just trying to load the evermotion libraries, giving them the correct path and also trying to fix the libraries as some of them for eg archmodels 136 said couldnt find AM136_01_*.max couldnt be found. finally got all the libraries to work
Amit
« Reply #5 on: August 21, 2018, 04:58:38 pm »
Hi, Library loading involves many Max processes which cannot be done while IPR is running.
For next updates, we'll disable the Library button when IPR is used, to avoid problems.
amitgedia
« Reply #6 on: August 21, 2018, 05:12:57 pm »
Thanks for the info, solution duly noted, its not a big  thing just inquired about it
Thanks again
Amit
