Author Topic: FP 7.05 Problems  (Read 5043 times)
Tryharder
FP 7.05 Problems
« on: March 08, 2021, 10:52:51 am »
Just upgraded to Forest Pro 7.05 from 7.04b
Vers 7.05 does not exept change of single geometrie.
i simply try to change from one tree to another ... does not work for me. ???
i have to delete old object in geometrie first
is that intended ?
if i replace one tree with an FP preset it works fine
but
if i try to replace one object of a preset with a single object it does not work
i will deinstall Forest Pro now and try a fresh install
« Last Edit: March 08, 2021, 11:07:24 am by Tryharder »
Re: FP 7.05 Problems
« Reply #1 on: March 08, 2021, 11:16:38 am »
Thanks for letting us know.
Tryharder
« Reply #2 on: March 08, 2021, 11:45:31 am »
Sorry
a complete new installation did not help
but i am shure you will find a solution as allways
thanks
Bost Digital
    • Bost Digtial
« Reply #3 on: March 09, 2021, 02:01:15 am »
Going to jump on this as well. Also having the same / similar problem. Can't swap out or add additional items to geometry list. I hit the plus for new item and then select my model and it seems like its loading then just says new model. Have to make new Forest with single item then add that item manually from selected object. Going to Downgrade to FP6 till this is sorted out. Way to time consuming to load one object per Forest.
Hopefully you guys can fix soon. Thank you
« Reply #4 on: March 09, 2021, 07:49:04 am »
Top on the list. Not going to wait for more reports to pile up.
ezmerel2
« Reply #5 on: March 09, 2021, 09:51:22 am »
Same issues here, except I can swap out objects from my scene without issues- even swap out one loaded from the library with one from my scene.
My main issue is that the only way to load an object to an empty geometry list is to not use the + button, but rather click on the Library button. An additional problem is that after loading a library item that way I cannot add another...
Any ETA for update? Not quite sure if I should roll back to v6.
« Reply #6 on: March 09, 2021, 10:35:32 am »
Bug is already fixed for next update. I guess we'll publish a patch today later, or tomorrow.
