Author Topic: FP_7 strange behavior of lights in a group  (Read 4130 times)
DT2656
« on: March 09, 2021, 06:56:17 am »
When trying to rotate a lantern consisting of a group (pole, shade, light source), only the pole is tilted, the shade and light rotates around its axis but not together with the group's pivot point.
Is this how it should be or is this issue not yet finalized?
Re: FP_7 strange behavior of lights in a group
« Reply #1 on: March 09, 2021, 07:46:44 am »
Hi.
Groups are tricky, does not matter if it has lights or anything else. I would recommend reading this grouped objects thread.
Anyway, short answer is- You can use noise map to unify randomization:
DT2656
« Reply #2 on: March 09, 2021, 08:08:45 am »
Thanks. Everything worked, the problem was in the pivot points.
