Forest Pack => Forest Pro (*) => Topic started by: CO2263 on November 26, 2013, 02:26:44 pm
Title: a bug ?
Post by: CO2263 on November 26, 2013, 02:26:44 pm
Hi everybody,
Just wondering if it's a bug or can be fixed
I imported lots of plants into scene and plant them manually in edit tree mode
then I noticed the scene is over 1.5gigs, so I started to convert each plant/tree into vrayproxy
All forest geometry objects were gone, when I picked again each geometry object name and pointed to a new proxies - plants still never show up.
Forest says I have 79 items but they are not visible (geometry is not assigned to each item)
Hope you understand mu problem
Thaks
Title: Re: a bug ?
Post by: yuv on November 26, 2013, 04:07:13 pm
The problem is when the object is converted to proxy, internally a new object is created and the mesh is deleted. As there is no any method to track this conversions, Forest loses the reference to them. You should re-connect each geometry item with their corresponding proxy to fix the scene.
Anyway, the best way to save space in the scene are X-Refs. Instead Proxies, they are a native characteristic of 3dsMax and are much more easily to track them internally. Besides this, they are more efficient (http://forum.itoosoft.com/index.php?topic=863.0) both in edition and render with Forest Pack.
If you use library items, or create your own libraries, there is an import option (http://www.itoosoft.com/forestpack/reference/library_browser.php) to keep all trees references as XRefs automatically, saving a lot of space in your files.
Title: Re: a bug ?
Post by: CO2263 on November 27, 2013, 07:51:32 am
Thats the point - I picked new proxy for each geometry in the list - and they didnt appear
Looks like when it lose geometry it cannot recreate it again
I just double-checked again, yes, thats true
I selected a new proxy for the geometry and its not going to appear, all nodes are somewhere blanks (as I see there are still 125 items)
Pls note - I'm in edit tree mode (plant manually each item)
Thx
Title: Re: a bug ?
Post by: CO2263 on November 27, 2013, 07:55:31 am
have no time for bug fix... (((
started to replant all items again using proxies
Title: Re: a bug ?
Post by: CO2263 on November 27, 2013, 08:22:41 am
looks like problem solved
just found all new proxies had pivot placed in 0,0,0 system coordinates
centered to objects and geometry appeared at its place
thx )
