Author Topic: a gradient mix between 2 objects  (Read 3453 times)
EO3276
« on: December 01, 2018, 10:48:25 pm »
Hi! I need to make a gradient mix between 2 different objects inside one forest object.
For example, 2 different color cobble stones that gradiently mix into one another. Is there a way to define the distance falloff for each object separately depending on a border or a spline?
In the attachment you can see the desired end result.
Thank You in advance
« Last Edit: December 01, 2018, 10:50:24 pm by EO3276 »
Re: a gradient mix between 2 objects
« Reply #1 on: December 03, 2018, 10:10:24 am »
Would it work for You if it was using Gradient Map?. I have attached my scene using customized effect:
