Author Topic: A message in a file without any forest objects.?  (Read 9669 times)
Nir Sullam
« on: August 09, 2010, 05:06:40 pm »
I get this message in a file. This file does not have any forest obj  in it(I made sure no templates are frozen or existing)
(I did use a some geomtry from a file that has forest obj)
Regards
Nir
Re: A message in a file without any forest objects.?
« Reply #1 on: August 09, 2010, 05:53:11 pm »
Does it happen if you reset Max and reload the scene ?
Nir Sullam
« Reply #2 on: August 09, 2010, 06:49:40 pm »
yes
even after restart it still gives the same message - I checked - no forest obj with that name.
« Reply #3 on: August 09, 2010, 08:04:29 pm »
Ok, please send us the file to check it.
Nir Sullam
« Reply #4 on: August 10, 2010, 12:13:21 am »
Carlos
The problem was solved -  an empty forest object was embedded inside a group and after I removed it - the msg was gone.
NIR
