Author Topic: Scatter object on animated terrain  (Read 7107 times)
Fabrice
« on: February 28, 2024, 04:19:34 pm »
I'd like to grow vegetation all over a animated robot.
But the scattered objects (plants) are allways change places when the robot's limbs move.
How to prevent that jittering please?
How to lock plant to the mesh all over the animation?
Fabrice
Max 2017 + FP pro 7.4.3
Re: Scatter object on animated terrain
« Reply #1 on: February 29, 2024, 09:06:48 am »
Hi Fabrice,
I'm sorry to hear you're facing trouble with it. We modified the UV mode some time ago to adapt better to the animated deformation of used surfaces (where the poly-count and UV mapping don't change). If you encounter any issues with it, would you mind send us your scene to check it here?
Let me mention, that for some scenarios (especially when using the UV mode and dealing with deformed UV space over time), the workflow described in the following "Scattering on the animated surface" post can be helpful.
Thanks in advance for any further comments on this issue you can share with us or our user community (in case other users encounter similar issues).
Fabrice
« Reply #2 on: February 29, 2024, 09:35:28 am »
Here's the scene (Max 2021 + FP 7.4.3).
PS : I know I can achieve this with tyflow but I'd like to do it with FP to take advantage of it's scattering capacity
« Last Edit: February 29, 2024, 09:37:43 am by Fabrice »
Fabrice
RealViz
    • RealViz
« Reply #3 on: February 29, 2024, 10:29:49 am »
Just torn off collisions and increase the density to e.g. 650cm...
edit: see attach.
« Last Edit: February 29, 2024, 10:40:59 am by RealViz »
« Reply #4 on: February 29, 2024, 10:51:18 am »
Thanks for the provided scene. Exactly, it's being caused by the Distribution > Collisions feature - once disabled, it works just fine. Please find attached the modified scene. I hope that helps.
Fabrice
« Reply #5 on: March 01, 2024, 09:46:10 am »
Thanks both for the answer!
Fabrice
