Toggle navigation
Login
Register
Forest Pack
Forest Pro (*)
UV Distrubution help
« previous
next »
Print
Pages: [
1
Author
Topic: UV Distrubution help (Read 14751 times)
RealViz
Sr. Member
on:
October 11, 2024, 03:29:55 pm »
Hi, I'm trying to create a grass paving. For some reason, however, the distribution of FP over UV only works on certain areas. I'm attaching an archive (max 2024) with a simplified scene with almost no textures etc.
tyFlow nedded -> tySelect mod.
Logged
ITOOSOFT
Hero Member
Re: UV Distrubution help
Reply #1 on:
October 14, 2024, 10:48:13 am »
This issue is caused by negative values in one of the
UVW Xform
modifiers. Using a rotation of
357°
instead of
-3°
appears to resolve the problem. Please find the revised scene (
241014_FP_UV_distribution_ITOOSOFT.max
) attached. I hope this helps!
Logged
RealViz
Sr. Member
Reply #2 on:
October 14, 2024, 11:32:04 am »
Thanks, it's weird anyway. The texture + displace works quite correctly. I guess I'll have to remember that it's causing problems with FP.
Logged
RealViz
Sr. Member
Reply #3 on:
October 14, 2024, 02:09:53 pm »
The problem seems to be bigger than that. On another project, a similar bug appeared and this time without a single UVW-Xform.
Logged
ITOOSOFT
Hero Member
Reply #4 on:
October 15, 2024, 11:03:23 am »
We appreciate your feedback. That's interesting - it will require a deeper investigation by our main developers. We'll keep you updated. Have a great day!
Logged
RealViz
Sr. Member
Reply #5 on:
October 15, 2024, 11:59:59 am »
Thank you, I'm also trying different variations. It's weird. In most cases, when I have for example a mask for forests on a large area, everything works as it should. If I figure something out, I'll post an observation.
Logged
Print
Pages: [
1
« previous
next »
Forest Pack
Forest Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
