Author Topic: WARNING: The Populate data is missing on your system.  (Read 4035 times)
sgutendorf
« on: March 04, 2022, 12:41:11 pm »
i have a problem with a scene. After worked and saved the scene yesterday I can´t open it anymore and get the message:
Maximum Nested Error Dialog Depth Reached.
See the attached Max.log File.
It is a 3ds Max 2021 scene with Forest 7.1.2 objects.
In the scene are many different XRefs and a few additional Objects, Lights and Cameras, nothing more.
All The Xrefs I can open without any problems.
I also create the File new and Xref the additional files. When I close the file and reoped it I get the same massages.
Can you please help me?
Re: WARNING: The Populate data is missing on your system.
« Reply #1 on: March 04, 2022, 12:47:37 pm »
I've looked up your error and it would appear to be a max issue caused when the user files get corrupted. You can read more about it here: https://knowledge.autodesk.com/support/3ds-max/troubleshooting/caas/sfdcarticles/sfdcarticles/3ds-Max-maximum-nested-error.html
I hope that helps,
