Author Topic: AcesCG workflow  (Read 32075 times)
grue
AcesCG workflow
« on: February 28, 2024, 04:36:54 pm »
hello.  is forestpro working with acescg workflow in vray 6.x and 3dsMax2024?  as of now, i have to select the material from the scene object and convert bitmaps to vray bitmaps, then manually set "Color space transfer function"  and "RGB color space parameters".
i tried using a vray bitmap converter, and that really messed up those two things i mentioned above. then i have also just right-clicked and changed the bitmap type.
thanks.
Re: AcesCG workflow
« Reply #1 on: February 29, 2024, 10:04:27 am »
The recently introduced Color Management (Rendering > Color Management) is now supported, and you have the option to use the OCIO Color Management Mode. However, I should mention that currently, the texture maps included in our bundled assets do not have "_lin_srgb," "_srgb", or "_acescg" suffixes. These maps are loaded within the Bitmap maps, so if you opt for the ACEScg workflow, you will need to make these adjustments as needed. Thank you for your understanding.
grue
Re: AcesCG workflow
« Reply #2 on: May 11, 2024, 12:08:37 am »
from what i could tell from reading vray docs and looking at vray assets from cosmos, the idea is that you could also go through the bitmaps > convert them to vraybitmaps > then set the color space transfer funtion & further down, RGB primaries to sRGB & sRGB primaries.
now, for forest objects i was using the built in vray converter bitmap to vraybitmap.
for my last playing around with it, the colors aren't going to be super exact render-to-render, but it's pretty close to the old gamma workflow.
the other thing is, in the 3ds max color management settings i set my displays and views like the attached image.  this gives me the benefit of saving out a 16bit tif file from the vray frame buffer. so you get not only the wider color gamut, but also greater bit-depth in the image which is the best way to capture and work with all the colors you can.
in the vray frame buffer, when you are going to save, make sure include the option to save the color profile (aRGB) in the image when you save it.
finally, i think that doing the "the color space transfer funtion & further down, RGB primaries to sRGB & sRGB primaries" set like this assumes the maps are in srgb to begin with.  which i think is pretty safe to assume depending on where you get your actual bitmaps.  downloading a logo  for a company from their website, you assume it was prepared with srgb in mind.  srgb is more or less the standard and has been for a long time.
the cosmos trees i have in a scene right now are all set to srgb/srgb so that means they prepared the leaves and the trunk/branch maps in srgb.
grue
Re: AcesCG workflow
« Reply #3 on: May 14, 2024, 08:38:40 pm »
i shold also mention, for me to get the closest match to the frame buffer when opening a file saved out... i save the file as a 16bit tif and again check that box for saving the profile in the image.  when i open it in photoshop, i set it so that PS prompts me what it wants me to do because there is no color profile embedded.  i choose "assign adobe rgb".
edit: and by the way, what i don't show as a screen shot is that there are Input Image Files > Automatic Color Space Assignment Rules rollout further down the color management settings.  i have my rules set to be the following screen shot.
if i'm correct on all of this, you no longer necessarily need to change image file names with _srgb or _lin_srgb  this looks like a place where we can set the default of images from the web or manufactures (carpet, tile etc) all can be assumed to srgb so we don't have to change anything. and playing around with this lately, the grass preset does look different from a gamma workflow render but it's not rediculously out of wack.
« Last Edit: May 14, 2024, 08:43:26 pm by grue »
ritoo
Re: AcesCG workflow
« Reply #4 on: February 17, 2025, 10:17:23 am »
Any chance to implement an "ACEScg-ready"option when loading a preset from FP library? Without name tagging, but with proper color space transfer function and  sRGB primaries? Its 2025, time has come..
P.S. or, at least, maybe  make a script in FP Toolbox to convert a selected forests to ACES?
« Last Edit: February 17, 2025, 10:20:10 am by ritoo »
grue
Re: AcesCG workflow
« Reply #5 on: February 17, 2025, 06:28:21 pm »
i need to mention that i found a paid script called "V-rayMax Converter Pro" and it has an Advanced Tool tab that allows me to convert bitmaps to the ACESCG proper settings in any scene. i use it to convert other materials to vray  materials as well.  not sure if you are using vray specifically?  not sure if we are allowed to post links but here it is: https://maxtools.3dzver.ru/vmcpro
