Author Topic: Missing creation tools in custom edit mode  (Read 4953 times)
Renderus
    • Renderus
« on: October 30, 2018, 11:44:32 pm »
I need some help. I'm missing the creation tools in Forest, when I enter custom edit mode. I have Forest 6, but in previous version it worked.
Please see attached.
Regards,
Marko.
Re: Missing creation tools in custom edit mode
« Reply #1 on: October 31, 2018, 07:48:48 am »
New previous creation tools are in distribution rollout. With more modes parameters and functions.
Renderus
    • Renderus
« Reply #2 on: October 31, 2018, 10:37:04 am »
Hi Rokas,
Can you please refer this with print screen?
As I still can't find the creation tools in distribution rollout (please see attached, as I'm in custom edit mode).
Thanks.
« Reply #3 on: October 31, 2018, 11:07:30 am »
Use Generate Mode instead of Custom Edit + Very first option:
Renderus
    • Renderus
« Reply #4 on: October 31, 2018, 11:29:44 am »
Thank you Rokas!
This is even better compared to the previous creation tools, it's actually interactive  :).
One more question, is there maybe an option that makes this distribution along the path more broad (more thick)?
Thank you very much.
Regards.
« Reply #5 on: October 31, 2018, 11:47:43 am »
Exactly- interactive!
For thickness You should use regular Image Distribution + Spline as Area.
Then You can adjust its thickness:
Hopes this helps
Renderus
    • Renderus
« Reply #6 on: October 31, 2018, 11:56:04 am »
Great, it does!
Thank you for your help.
DT2656
« Reply #7 on: June 24, 2019, 05:56:51 am »
And how to deal with items that should be distributed at a clear interval, with cars in the parking lot, all the old presets now do not work.
Please show me an example of how to make an equal distance between trees planted in a single line, for example, an interval of 3.5 meters. Cars in the parking lot 2.5 meters.
« Reply #8 on: June 24, 2019, 12:44:15 pm »
To do that you can use the new Spline mode.
This allows you to space items at precise distances along the spline, but with the added benefit of remaining completely parametric at all times so it's possible to make changes without needing to delete all the previously distributed items.
Hope that helps,
DT2656
« Reply #9 on: June 25, 2019, 06:52:24 am »
Thank!
Could you please update this https://www.itoosoft.com/ru/tutorials/parking-cars?back=page%3D7 using the effects tab. Or create another short one considering the changes that occurred in the plugin.
