Author Topic: Combine or Merge forest objects question  (Read 4759 times)
ML2660
« on: January 30, 2016, 10:29:48 pm »
Hi there,
I'd like to know if it is possible to combine forest object into one forest object.
I've bought vizpark real grass and this consists of multiple forest object to create on field of grass.
So to create an exclusion area/paint area for  example, you have to do this for every forest  object.
Is there a solution or workaround for this
Searched the answer in the manual and forum but couldn't find it.
Ml
Re: Combine or Merge forest objects question
« Reply #1 on: January 31, 2016, 08:31:18 am »
Hi, yes it's possible but in "Custom Edit" mode only, using Attach Simple/Multiple options.
This feature is not available in "Generate" mode because there is no way to keep the distribution from different Forest objects. Anyway, you can switch to Custom Edit temporary, attach, come back to Generate mode and adjust the distribution of the resulting Forest.
ML2660
« Reply #2 on: January 31, 2016, 09:43:14 am »
Thx for the quick reply!
I'll give it a try
Ml
