Forest Pack => Forest Pro (*) => Topic started by: ES1947 on October 01, 2015, 12:26:51 pm
Title: adding objects just by painting?
Post by: ES1947 on October 01, 2015, 12:26:51 pm
hi
sorry, this might be a noob question.
normally i just add forest pro objects by selecting an object / face.
but what if i only need objects on a small part of the surface?
right now i select the whole terrain, add objects (that's a lot of objects), and then use the paint tool to remove objects (lot of work).
is it possible to do the opposite - just paint where i want the objects?
thanks
Title: Re: adding objects just by painting?
Post by: Michal KarmazĂ­n on October 01, 2015, 01:00:09 pm
Yes, that's possible - for these purposes use the Paint Area (http://docs.itoosoft.com/display/FORESTPACK/Areas#Areas-PaintAreaProperties) in the Include mode. Just please double check, that the Surface Area isn't switched On (and covering the whole surface which would "double" the distribution).
Let me add, that a "Surf Mat.ID" feature is already supported (since the Forest Pack Lite/Pro 4.3.3 (http://forum.itoosoft.com/index.php?topic=2691.0) - Added Areas->Limit by Surface Material ID.). You can find more about it in our "To limit the scatter using material (http://docs.itoosoft.com/display/FORESTPACK/Areas#Areas-TolimitthescatterusingmaterialIDs)" section of our on-line reference guide.
Hope that helps.
