Author Topic: Forest and Railclone never remember texture links  (Read 4291 times)
quadrantatelier
« on: October 17, 2025, 09:46:51 pm »
Ive had this problem for a while. I understand some forums have said well just relink the textures using the configure projects paths and set a texture path for every folder of plants and other things i will ever use, but this gets just old. Ive reset windows, ive reinstalled 3ds max, but railclone and forest pack never ever remembers where the textures are when imported. Whats worse, everytime i save and reopen the file, it forgets them again so i have to relink everything again. Can anything be done about this because its driving me nuts.
thanks
Re: Forest and Railclone never remember texture links
« Reply #1 on: October 20, 2025, 01:03:21 pm »
First, let me mention that textures for any items handled by our plug-ins are treated like any other asset in the scene. Simply setting the correct paths in 3ds Max under Customize > Configure User Paths > External Files (stored in 3dsmax.ini) should be sufficient. If the Asset Tracking tool shows the status as Found for those textures, there shouldn’t be any problem.
If preferred, using environment variables can be a good option. In recent versions of 3ds Max, you can use environment variables for this purpose (for example, ADSK_3DSMAX_ASSETS_MAPS_DIR). Please see the following link for more details:
https://help.autodesk.com/view/3DSMAX/2026/ENU/?guid=GUID-D7D373FD-CA78-4986-AB3D-B1E25F2A37CC
Let me add that, in general, we recommend resolving all references used by our plug-ins to absolute UNC paths using the Asset Tracker. It’s not strictly necessary, but this approach usually helps avoid texture path issues when using distributed rendering. The “default” file handling is controlled by 3ds Max and can be adjusted under: Options > Preference Settings > File Handling > Convert file paths to UNC. This ensures that all your scenes use UNC paths consistently.
I hope this helps.
quadrantatelier
« Reply #2 on: October 21, 2025, 02:58:01 pm »
Is there no way in which 3ds max and your plugins automatically save the paths without having to go into configure user and system paths and adding every folder of every texture in there manually? This is very time consuming as i must have over 1000 texture folders. And why doesent RC and FP save the textures or add the texture paths into configure user and system paths automatically? I just dont understand why i have to mannually do this? If use the material editor and add a texture via a bitmap, why cant 3ds max automatically add and save that path so that next time i wont have to relink the textures again?
« Reply #3 on: October 22, 2025, 08:42:30 am »
Yes, there is. When the plug-in is loaded, it automatically adds the necessary paths for bundled or previously added libraries to the external files list. It checks whether the paths specified in the following registry keys exist:
  • HKEY_CURRENT_USER\Software\Itoo Software\Forest Pack Pro\TexturePaths
  • HKEY_CURRENT_USER\Software\Itoo Software\RailClone Pro\TexturePaths
If these paths don’t exist, the plug-in can add them automatically (a warning message will be displayed). If you previously checked the Do not show this message again option to disable the pop-up, you can restore it by setting checkTexturePaths = 1 in the forestpack.ini configuration file. By default, this file is located here:
C:\Users<yourUsername>\AppData\Local\Autodesk\3dsMax<maxversion>\ENU\en-US\plugcfg
That said, if you use absolute UNC paths, there’s no need for any complex path configuration setup. Let me add, that as mentioned in this closely related post:
"... asset management preferences and workflows vary widely among users. As noted above, 3ds Max itself must be configured correctly—our plugins aim to assist with automation, but there’s no single "correct" setup that fits every environment. Thanks for your understanding."
